Getting weird jagged lines on PV-Battery heatmap
  • Aproop
28 Nov 2023 02:50 #12698 by Aproop
Hi folks
I've just run a grid-connected PV battery system with a custom load. I used default sizing options for the PV modules, inverter, and battery and used the peak shaving algo for battery dispatch. Why am I getting this weird jagged line output on the file?
28 Nov 2023 11:09 #12699 by Paul Gilman
Replied by Paul Gilman on topic Getting weird jagged lines on PV-Battery heatmap
Hi Aproop,
I'm not sure what you mean by "weird jagged line output on the file." If you need help troubleshooting, please tell me what output variable you are plotting, and if possible attach a .sam file or screenshot so I can understand your question.
  • Aproop
28 Nov 2023 23:30 - 30 Nov 2023 15:37 #12701 by Aproop
Thanks Paul: I attached the .png file in my original post, pasted here for ease: also attaching the sam file.
Last edit: 30 Nov 2023 15:37 by Paul Gilman. Reason: Insert image as attachment
30 Nov 2023 16:27 #12708 by Paul Gilman
Hi Aproop,
This is a rendering problem with SAM's data viewer for data with sub-hourly time steps. I created an issue on GitHub: github.com/NREL/SAM/issues/1616
Thank you for letting us know about this.
