Period,
  • JohanS
09 Nov 2023 05:30 - 10 Nov 2023 18:05 #12634 by JohanS
Period, was created by JohanS
Morning, please can you respond to the following.
  1. In South Africa the TOU rates are different for Saturdays and Sundays, can this be modelled as only Weekdays and Weekend input tables are available, see picture below.
  2. As tariff increases are not starting on the 1st of January, we require 12 periods to complete tariff calculations, the tables does not want to accept inputs above 9, see pictures above and below.
  3. Is it possible to change the currency to local currency (R)
Last edit: 10 Nov 2023 18:05 by Paul Gilman.
10 Nov 2023 18:10 #12637 by Paul Gilman
Replied by Paul Gilman on topic Period,
Hi Johan,
SAM assumes that January 1 is a Monday, and that weekends are Saturday and Sunday. It is not possible for Saturday and Sunday to have different TOU periods.
You can specify up to 36 TOU periods. Use the letters "a" through "z" in the Weekday and Weekend schedule matrices for Periods 10 through 36.
It is not possible to change the currency symbol in SAM.
  • JohanS
14 Nov 2023 22:11 - 15 Nov 2023 18:34 #12650 by JohanS
Replied by JohanS on topic Period,
Morning Paul,
Thanks, the TOU table was fixed and now reflects the 12 TOU tariffs using "a" to create the 11 and "b" to create the 12 in the TOU tables (Weekday and Weekend).
Last edit: 15 Nov 2023 18:34 by Paul Gilman. Reason: Insert images as attachments
15 Nov 2023 18:36 #12655 by Paul Gilman
Hi Johan,
Be sure to set the "Tier" value in each row to 1, and the "Max. Usage" value in each row to a very large number like 1e38.
