Wind error with CSV exec fail(windpower): error reading wind resource file for..
- Anna N
31 Oct 2023 15:19 #12605
by Anna N
Wind error with CSV exec fail(windpower): error reading wind resource file for.. was created by Anna N
Hello, I've searched the help forum but can't find this answer.My data are resulting in an error no matter the format I use, whether I have data for every hour for just wind speed, all wind speed data + one of wind direction + temp + air pressure, or data for each of these for every hour. I've also tried using the format that the SAM downloads are in, although the Help page on CSVs seems to indicate this isn't necessary (added columns for Year, Month, Day, Hour, Minute).
These wind values are for a region in Bhutan, so I can't use the available SAM data.I've searched the help forums and the internet. Can someone help me? exec fail(windpower): error reading wind resource file for interpolation at time step 0:
Simulation windpower failed :exec fail(windpower): error reading wind resource file for interpolation at time step 0:
- Anna N
01 Nov 2023 18:29 #12614
by Anna N
Replied by Anna N on topic Wind error with CSV exec fail(windpower): error reading wind resource file for..
Fixed this with conversion to .srw, but the Help file does say a CSV will work now? What is going on?
02 Nov 2023 17:15 #12617
Replied by Paul Gilman on topic Wind error with CSV exec fail(windpower): error reading wind resource file for..
Hi Anna,
The CSV file should have worked -- I couldn't see what was causing the problem either.
Would you mind attaching the SRW file so I can investigate further?
- Anna N
02 Nov 2023 17:52 #12618
by Anna N
Thank you!
Here is one of the srw's that are working, copied from the examples.
07 Nov 2023 10:45 #12627
Hi Anna,
Did you mean to attach an SRW file? I don't see an attachment with your most recent post.
