Set desired water temperature for solar thermal model?
  • Jarett Diamond
05 Mar 2013 11:56 #1388 by Jarett Diamond
I want to model a solar thermal collector system which produces up to 170 degF hot water. Is it possible to set a custom desired hot water temperature in SAM? Can this desired hot water be given different values for each month?
Thank you.
05 Mar 2013 12:48 #1389 by Paul Gilman
Dear Jarett,
The "Auxiliary Set Temp" determines the temperature of water delivered by the system. It is not possible to specify a different set temperature for each month.
  • Jarett Diamond
08 Mar 2013 08:50 #1390 by Jarett Diamond
Replied by Jarett Diamond on topic Set desired water temperature for solar thermal model?
If my auxiliary system is a tankless hot water heater, what value should I list for Auxiliary Volume? Should I list the same as the Solar Tank Storage Volume?
