AWS SAM Template - Defining Environment Variables for Lambda Function
- Vishal
14 Aug 2023 02:47 #12413
by Vishal
AWS SAM Template - Defining Environment Variables for Lambda Function was created by Vishal
I'm working on an AWS Serverless Application Model (SAM) project and I'm trying to define environment variables for my Lambda function within the
file. I want to set specific configuration values that my Lambda function can access at runtime.I've looked through the AWS SAM documentation, but I'm having trouble finding a clear example of how to define environment variables directly in the template.Could someone provide guidance on the proper syntax and structure to define environment variables for a Lambda function using AWS SAM? Are there any best practices or considerations I should be aware of when setting up environment variables within the SAM template?Here's a snippet of what I have so far:
Is this the correct approach, or am I missing something? Any help would be greatly appreciated. Thank you!
template.yaml
Resources:
MyLambdaFunction:
Type: AWS::Serverless::Function
Properties:
CodeUri: ./my-lambda-code
Handler: index.handler
Runtime: nodejs14.x
Environment:
Variables:
MY_CONFIG_KEY: "my-config-value"
14 Aug 2023 10:11 #12416
Replied by Paul Gilman on topic AWS SAM Template - Defining Environment Variables for Lambda Function
Hi Vishal,
Wrong SAM! This is a forum for NREL's System Advisor Model (SAM).
For the AWS Serverless Application Model (SAM), see aws.amazon.com/serverless/sam/ .
