Ground Clearance Height
- Andrew Hoyt
07 Aug 2023 09:37 #12380
by Andrew Hoyt
Ground Clearance Height was created by Andrew Hoyt
For fixed tilt systems - is the "ground clearance height" value measured from top of grade to the bottom/lowest edge of the module?
07 Aug 2023 14:17 #12383
Replied by Paul Gilman on topic Ground Clearance Height
Hi Andrew,
The ground clearance height is an input for bifacial modules on the Module input page.
For fixed arrays with no tracking, the ground clearance height is the distance between the ground and the bottom edge of modules closest to the ground. For arrays with one-axis tracking, the ground clearance height is the distance between the ground and back of modules when the modules are horizontal to the ground.
- Claud Balgobin
07 Apr 2025 11:33 #13980
by Claud Balgobin
Replied by Claud Balgobin on topic Ground Clearance Height
Can SAM model the Ground Clearance for fixed mono facial PV panels say 300 mm above the ground from the low side?
And if so, how can this be done?
Claud
Claud
07 Apr 2025 11:43 #13981
- Andrea
19 Oct 2025 21:13 #14335
by Andrea
Replied by Andrea on topic Ground Clearance Height
If the Ground Clearance Height is disabled for monofacial modules, does that mean it does not have an effect to the systems if I enable it momentarily to change the default value and disable it again before simulating a monofacial system?
Additionally, I am aiming to observe the effect(s) of different albedo values on monfacial and bifacial modules. According to literature, albedo affects the height and tilt angle (among other things) of both systems, so I want to find the height and tilt angle where they can have the most output using parametric simulations before using those values in another simulation to get other results. However, as you have said, the Ground Clearance Height is only enabled for bifacial modules. Thus, I would like to know if there are any assumptions or a default height from the ground used in SAM regarding the Ground Clearance Height of monofacial systems. I scanned the Photovoltaic Model Technical Reference Update but I can't seem to find an exact height/number. Thanks!
Andrea
Andrea
20 Oct 2025 10:53 #14336
Hi Andrea,
In the internal code for the Detailed PV model, the ground clearance height is used in the 'calc_rear_side' function , which only gets called for bifacial modules. If you clear the Module is bifacial checkbox on the Module page in SAM, that function never gets called. So, yes, if you switch to bifacial mode, change the ground clearance height, and then switch back to monofacial mode, SAM does not use the ground clearance height for irradiance calculations.
For bifacial modules, SAM calculates the irradiance that reflects on the rear of the module, accounting for shadows caused by the modules, which requires the ground clearance value.
For monofacial modules, the ground reflectance is treated as uniform, and is not affected by ground clearance, as described in Section 6.4 of the PV reference manual, Gilman, P.; Dobos, A.; DiOrio, N.; Freeman, J.; Janzou, S.; Ryberg, D. (2018) SAM Photovoltaic Model Technical Reference Update. 93 pp.; NREL/TP-6A20-67399. ( PDF 1.8 MB ).
Note that we wrote the reference manual before SAM could model bifacial modules. For documentation of SAM's bifacial model, see the references listed under "Bifacial Modules" on the PV Publications page: sam.nrel.gov/photovoltaic/pv-publications.html .
