Model just battery dispatch (Detail PV+Battery)
  • Aliasgar Parekh
19 Jun 2023 17:22 - 20 Jun 2023 23:00 #12238 by Aliasgar Parekh
Model just battery dispatch (Detail PV+Battery) was created by Aliasgar Parekh
I am trying to model battery dispatch from 4pm to 9pm. However, 'system power' in the time series shows that it is combination of solar+battery. Can we program in which dispatch is only by battery and not combined with solar?
Please guide me. Thank You.
Ali
Last edit: 20 Jun 2023 23:00 by Paul Gilman.
20 Jun 2023 23:07 #12243 by Paul Gilman
Replied by Paul Gilman on topic Model just battery dispatch (Detail PV+Battery)
Hi Ali,
SAM's manual battery dispatch option uses PV array power if it is available to meet the load to minimize battery throughput losses and battery cycling. You could use the "system availability" losses at the bottom of the Losses input page to force the PV output to zero during those times by setting the DC loss between 4 and 9 PM to 100%.
  • Aliasgar Parekh
21 Jun 2023 01:27 #12244 by Aliasgar Parekh
Replied by Aliasgar Parekh on topic Model just battery dispatch (Detail PV+Battery)
Thank You Paul. I understand.
I have one more query regarding the same - In the dispatch section, if I have selected 'Discharge battery only when load exceeds system output' then is it possible to see solar generation in 'Time series' separately and not combined with battery power? When I select 'System power generated (kW)' - it shows solar + battery power combined. Refer attached image.
Best Regards,
Ali
27 Jun 2023 01:08 #12254 by Paul Gilman
Hi Ali,
The "Subarray 1 DC power gross" output variable indicates the PV array output. It does not include any AC losses from the Losses page.
