Windrose & windfarm layout input format -
- Leopoldo
27 Mar 2023 14:39 #12018
by Leopoldo
Windrose & windfarm layout input format - was created by Leopoldo
Hi all,Is it possible to generate a wind rose with the downloaded wind data?..when we import a wind farm layout, SAM expects a file with 2 columns with data in meters (similar to UTM coordinates). Could someone upload an example file to see the structure?…
best,
Alvarez
best,
Alvarez
28 Mar 2023 06:41 #12019
Replied by Paul Gilman on topic Windrose & windfarm layout input format -
Hi Alvarez,
SAM does not generate wind rose plots.
The CSV format for wind is described in SAM's Help system, in the "Weather File Formats" section. Attached is an example.
- Leopoldo
28 Mar 2023 06:50 #12021
by Leopoldo
Replied by Leopoldo on topic Windrose & windfarm layout input format -
thank you,
in the second question I was referring to how SAM expects the input files regarding importing a wind farm layout.
best,
Alvarez
thank you,
best,
Alvarez
28 Mar 2023 07:05 #12023
Hi Alvarez,
The file format for the wind farm layout is described in the "Wind Farm" topic in Help. Attached is an example.
- Leopoldo
28 Mar 2023 10:19 #12024
by Leopoldo
Thank you Paul.
Hi all users,
Any tool that you recommend to make a wind rose with the data downloaded from NREL's windtoolkit? What do you use? I work on OSX Mac System.
best,
Alvarez
Hi all users,
best,
Alvarez
- Henry Foss
10 Apr 2023 02:11 #12049
by Henry Foss
Replied by Henry Foss on topic Windrose & windfarm layout input format -
Hi Alvarez,
As far as I am aware, the only open source tool which can do this is Continuum (website here) . I haven't used it much myself but it seems quite feature rich!
Matt
Matt
