Ground Irradiance
  • Daniel Marshal
01 Feb 2023 03:02 #11891 by Daniel Marshal
Ground Irradiance was created by Daniel Marshal
Hi all,
in SAM 2022.11.21, there are new updates about output for ground Irradiance. Can I get equation refference for this output. I checked the PV Technical Refference ( www.nrel.gov/docs/fy18osti/67399.pdf ) but can't find the related equation.
nb: Following variable that I mention as ouput :
- Irradiance incident on the ground within array
- Irradiance absorbed by the ground within the array
- Array POA rear_side radiation reflected from the ground after (IAM)
Thanks !
  • RANIA BENBBA
23 Oct 2024 18:13 #13547 by RANIA BENBBA
Replied by RANIA BENBBA on topic Ground Irradiance
This message contains secure information
24 Oct 2024 14:52 #13553 by Paul Gilman
Replied by Paul Gilman on topic Ground Irradiance
A description of the ground irradiance and rear irradiance calculations is available in the following document and code repository:
research-hub.nrel.gov/en/publications/viewfactor-and-raytracing-for-agripv-modeling
github.com/NREL/bifacialvf
