Frozen Simulation
  • Danilo Diaz
15 Jan 2023 12:18 #11833 by Danilo Diaz
Frozen Simulation was created by Danilo Diaz
Hello Everybody.
I don't what is happening that sometime the simulation is frozen around 30-40% complete and I have to force the exit of SAM to re-start the program.
I was simulatuin PV*BESS system with 11 MW, 15 MW, 22 MW, 30 MW and 48 MW.
When I try 30 MW the Simulation can't complete the simulation getting frozen around 30-40%.
Have Someone had the same experience?
Regards
16 Jan 2023 17:53 #11834 by Paul Gilman
Replied by Paul Gilman on topic Frozen Simulation
Hi Danilo,
Please reply with a .sam file attached that demonstrates that issue if you would like us to help troubleshoot.
  • Danilo Diaz
17 Jan 2023 22:55 #11837 by Danilo Diaz
Replied by Danilo Diaz on topic Frozen Simulation
Hello Paul.
Attached is the SAM file.
I have a OSX Notebook MAC PRO to make the simulation.
When I try to simulate the 30 MW Case. The simulation started slowly, then when it reached 40%, it got frozen and I had to forze to exit SAM.
Regards
Danilo
File Attachment:
File Name: TRADEOFF DET-01.sam
File Size:904 KB
18 Jan 2023 17:13 #11840 by Paul Gilman
Hi Danilo,
The simulation doesn't finish for the 30 kW case because of the grid outage requirement. If you remove the grid outage, the simulation finishes. This may be an indication that the 30 kW case cannot meet the grid outage as designed.
  • Danilo Diaz
18 Jan 2023 23:26 #11843 by Danilo Diaz
Thanks for your help.
First, I try to zero all grid outages values in the array (Didn't Work!)
Then, I try to remove the critical load requirement and the SAM, automaticallly, remove the grid outages values. (It works!)
The life come back again!
It worked but Grid Outages are quite common and must be simulated.
Regards
19 Jan 2023 10:10 #11847 by Paul Gilman
Hi Danilo,
This is a bug that we will fix either for the update planned for mid-February or for the next version at the end of this year:
github.com/NREL/SAM/issues/1324
