how to calculate thrust coefficient, power coefficient and turbulence intensity?
  • Hamza Ali
17 Nov 2022 23:02 #11707 by Hamza Ali
Hello sir, can you please explain how to calculate thrust coefficient, power coefficient and turbulence intensity?
Thrust coefficient formula is CT = 4a(1-a) equation 32 in wind SAM manual.
How to get the value of unknown variable "a", where a = axial induction factor.
In turbulence intensity formula equation 34, How to get the value of unknown variable "x", where x = cross wind distance between turbines in rotor radii. ??
Can you reply me as earliest as possible please!
28 Nov 2022 12:09 #11734 by Paul Gilman
Hi Hamza Ali,
Section 8.2.1 of the SAM wind reference manual describes the code in the turbinePower() function here:
github.com/NREL/ssc/blob/7b84c5b5eb73ab77bc72e081277c6c27a3a00f31/shared/lib_windwakemodel.cpp#L71
Specifically, the thrust coefficient and power coefficient equations are here:
github.com/NREL/ssc/blob/7b84c5b5eb73ab77bc72e081277c6c27a3a00f31/shared/lib_windwakemodel.cpp#L123
The turbulence intensity equations described in Section 8.2.2 are here:
github.com/NREL/ssc/blob/7b84c5b5eb73ab77bc72e081277c6c27a3a00f31/shared/lib_windwakemodel.cpp#L142
