Battery charge to system spike.
- Brock Tuppeny
14 Nov 2022 12:24 #11691
by Brock Tuppeny
Battery charge to system spike. was created by Brock Tuppeny
All/Paul,
I am modelling 2 wind cases and 1 solar case with a Generic + battery in a BTM system. I have set the battery dispatch so it can only charge from the system (charge from grid not enabled) when system>load and discharge only when load >than system (peak shaving button selected). I have entered a very small sell price in the sell column of the energy charges (buy/sell) all in order to get the economics to calculate a difference in the bill with and without system. files attache
The individual system cases run fine with logical outputs but when I simulate the Battery plus system, the LCOE calcs are absurdly high and the bill with the system is more than the bill without the system (huge negative savings).
Strangely, there also appears to be a single spike (on Sept 30th) when the battery sends electricity to the grid for one hour. But at that same time period, the system is sending power to the grid (i.e. surplus power over load is being generated by the system) and there is a non zero load in that same time period (in fact no zero load conditions. I have a sneaking suspicion that the LCOE calcs are only picking up this power spike as the total KWH divisor.
Any suggestions as to how to remedy?
15 Nov 2022 10:46 #11694
Replied by Paul Gilman on topic Battery charge to system spike.
Hi Brock,
The peak shaving battery dispatch option for behind-the-meter (BTM) systems attempts to reduce demand peaks, and is designed for situations where the electricity rate structure includes demand charges. See the "Battery Dispatch BTM" topic in help for more details: samrepo.nrelcloud.org/help/battery_dispatch_btm.htm .
On the Time Series tab of the results page, you can plot "Electricity to load from battery" and "Lifetime electricity load" to see that the battery discharges briefly on days that there is a load peak.
Can you tell me what scenario you are trying to model? The combination of buy all/sell all metering option and tiered energy rates seems unusual.
- Brock Tuppeny
15 Nov 2022 11:28 #11696
by Brock Tuppeny
Replied by Brock Tuppeny on topic Battery charge to system spike.
Thanks Paul,
Currently, existing Diesel gensets, PV farm and WT's supply the load. Gensets are dispatched to generate a min of 500 kW for efficiency, Solar comes in as generated and WT are operated to make up the rest of the load. I wish to model additional new WT's, Solar, and batteries with dispatch strategy of renewables first (and only they charge the battery) and the Gensets making up shortfalls when WT, PV, (and Battery if competitive) don't meet load. I want to minimize the LCOE for new equipment additions (of course) and thus would benefit from having the LCOE figures being sensible.
I had tried the Residential BTM model thinking to model the gensets as grid purchased power. I have the heat rates and fuel costs for the gensets so I input the $/kWh costs at different loads as the tiered energy buy rates, but was not sure how to get (or if SAM can calculate) the hour by hour grid (genset) cost on that basis as I think it only does the tiering on a daily/ monthly basis?. (but being able to do this would be a nice feature). The other issue I have, is surplus system power being sold back to the grid. I set the sell rates very low, which has the benefit that SAM does show a difference in bill with and without system (if sell rate is zero - there is no difference between the bills) but the total system power generation is now used as the basis for the LCOE calculation when in fact I would want to be curtailing WT generation when system greater than load. Not sure how to do this.
Still, SAM does track the Grid supplied power to system and system power grid, so in the interim if have been downloading these vectors and the load and calculating in excel a truncated system production and working out the correct costs for grid (genset) supplied power in the System and No system cases, and thus the savings from the system. and whacking that back into the exported cash flow model.
Any advice you can give about a better way to set up these configurations to reduce the extracting and external manipulation would be much appreciated.
- Brock Tuppeny
15 Nov 2022 11:51 #11698
by Brock Tuppeny
Additional Comments
The strange things (for me) are:
1. why the battery discharges to the grid when the battery is set to only discharge when Load is greater than system (why is it not meeting load first?) and if so, why only once per year for 9kW?
2. Why the savings due from the system are (so) negative? I find it hard to imagine how taking less power from the grid could be so much more expensive than taking it all from the grid; particularly when there is only a 50% difference between the highest and lowest price tier.
16 Nov 2022 16:50 - 16 Nov 2022 17:02 #11704
Hi Brock,
Thank you for the description -- I see what you are trying to do. That's a bit of a stretch for SAM (a model like HOMER is better suited for this kind of analysis).
With the buy all / sell all metering option, all of the power delivered to the grid by the system is sold at the sell rate(s), and all of the power required by the load and to charge the battery is purchased at the buy rate(s). The net billing (excess generation calculated for each time step) or net energy metering (excess generation calculated from monthly totals) may be better options. Detailed descriptions of the options are in the "Metering and Billing Definitions" section of the "Electricity Rates" Help topic: samrepo.nrelcloud.org/help/electricity_rates.htm
I think that will address Item 2 (negative savings).
For Item 1, it looks to me like the battery only discharges (blue) when the load (red) is greater than the system output (orange):
Last edit: 16 Nov 2022 17:02 by Paul Gilman.
