Error: Failed to solve for module coefficients.
- Joseph Lim
10 Oct 2022 02:56 #11542
by Joseph Lim
Error: Failed to solve for module coefficients. was created by Joseph Lim
I am getting the error "Failed to solve for module coefficients. Please check you inputs." I have checked that the data entered matched what is on the data sheet from the manufacturer.
I have attached a screenshot of the error and the pdf file of their datasheet.
Thank you for the help.
Joseph
Joseph
10 Oct 2022 16:50 #11548
Replied by Paul Gilman on topic Error: Failed to solve for module coefficients.
Hi Joseph,
The algorithm SAM uses to calculate model input parameters from datasheet specifications does not always converge on a solution. This is something we hope to fix in the future.
For now, you might try changing the cell type to see if that helps the algorithm find a solution (this input determines the initial conditions for the iterative solution, so it can be different from the module's actual cell type).
