Discrepancy in Wind Weather File between SAM GUI and API
- Abenezer Achmano
                03 Oct 2022 14:53                #11515
        by Abenezer Achmano
        Discrepancy in Wind Weather File between SAM GUI and API was created by Abenezer Achmano
I am encountering numeric differences between wind weather files I downloaded using the sam gui and directly from the api using R for the same location and year. I am attaching 2009 weather file downloaded through the api and directly through sam gui to showcase the numeric difference between the two files as an example.
Abenezer
Abenezer
                03 Oct 2022 18:17                #11516
        Replied by Paul Gilman on topic Discrepancy in Wind Weather File between SAM GUI and API
        Hi Abenezer,
Can you send me the URL your R code generates so I can investigate?
You can see how the URL that SAM uses is constructed in the webapis.conf file in your SAM installation folder or on GitHub here: github.com/NREL/SAM/blob/develop/deploy/runtime/webapis.conf .
- Abenezer Achmano
                04 Oct 2022 07:23         -  04 Oct 2022 17:08        #11520
        by Abenezer Achmano
        Replied by Abenezer Achmano on topic Discrepancy in Wind Weather File between SAM GUI and API
Thanks for your timely response. Here is the URL my R code produces:
Abenezer
https://developer.nrel.gov/api/wind-toolkit/v2/wind/wtk-srw-download?api_key=<key>&lat=39.83188&lon=-88.0723&year=2009&email=<email>&utc=true
Abenezer
        Last edit: 04 Oct 2022 17:08  by Paul Gilman.
                04 Oct 2022 17:41         -  05 Oct 2022 15:24        #11521
        Hi Abenezer,
Thank you for sending the URL. This was a bit of a puzzle to solve!
SAM makes the API call with no 'utc' parameter, so it is set to the default 'utc=false'. Your URL sets 'utc=true'. If you compare the data between the two files, you should see the data is offset by the difference between UTC and local time.
Note that there are two similar WIND Toolkit API endpoints that appear to return the same data in different formats. They also have different default values for the 'utc' parameter, so if you happen to be working with the 'wtk-download' endpoint, be aware of that difference:
developer.nrel.gov/docs/wind/wind-toolkit/wtk-srw-download/ (this is the one SAM uses, with "srw" in the name)
developer.nrel.gov/docs/wind/wind-toolkit/wtk-download/ (this one returns CSV files)
        Last edit: 05 Oct 2022 15:24  by Paul Gilman.
- Abenezer Achmano
                05 Oct 2022 10:03                #11526
        by Abenezer Achmano
That explains it! Thank you so much for the thorough answer, I really appreciate it!
Abenezer
Abenezer
- Hamza Ali
                03 Nov 2022 00:23         -  03 Nov 2022 11:37        #11644
        by Hamza Ali
        Replied by Hamza Ali  on topic Discrepancy in Wind Weather File between SAM GUI and API
        Hello Abenezer Achmano, I am Hamza Ali. I am doing my research on Wind by using SAM.
I am linked up with Sir Paul Gilman. I also want to connect with you.
I want to ask queries from you as well, it will be highly appreciated.
Waiting for your response.
        Last edit: 03 Nov 2022 11:37  by Paul Gilman.
