user defined new HTF physical properties
- Oussama Achkari
15 Sep 2022 06:49 #11463
by Oussama Achkari
user defined new HTF physical properties was created by Oussama Achkari
I'm running the physical parabolic trough model using 'user defined' HTF data for a new nano-fluid. However, I get negative net electrical energy production. knowing that when I run the same project with predefined HTF data from the proposed list, I get positive results. In the same perspective, I have noticed that when I use the 'user defined' HTF data, the cycle design HTF mass flow rate is not defined (NaN kg/s) and I don't know how to introduced it. Please, can you help?
Best regards
Best regards
19 Sep 2022 09:56 #11470
Replied by Paul Gilman on topic user defined new HTF physical properties
Hi Oussama,
I suspect that the HTF you are modeling has parameters outside the bounds of values SAM is expecting.
The equation for the Cycle Design HTF Mass Flow rate on the Power Cycle page is given in the Help topic for that page: samrepo.nrelcloud.org/help/troughphysical_power_cycle.htm . The NaN value could be caused by a divide-by-zero error.
- Oussama Achkari
21 Sep 2022 08:48 #11477
by Oussama Achkari
Replied by Oussama Achkari on topic user defined new HTF physical properties
Thank you for your answer, it was very helpful.
Best regards
Best regards
