DNI for power tower
  • oukili.mohamed
11 Feb 2013 10:03 #1277 by oukili.mohamed
DNI for power tower was created by oukili.mohamed
I noticed that in the system CSP parabolic trough collectors, SAM uses the DNI-cosine effect product values, but for the CSP solar tower system, it uses directly the DNI values. is that you can me explain it ??
11 Feb 2013 15:36 #1278 by Paul Gilman
Replied by Paul Gilman on topic DNI for power tower
I think you are referring to the fact that the physical trough model reports a variable in the results named "Collector cosine effect - cos theta" that the power tower model does not report. The power tower model reports the "Total incident thermal energy" that is comparable to the physical trough model's "Thermal energy absorbed."
Both models calculate the solar radiation incident on the solar field, but they use different variables in the calculations, and report different variables in the results.
  • oukili.mohamed
12 Feb 2013 04:51 #1279 by oukili.mohamed
Replied by oukili.mohamed on topic DNI for power tower
thank you very much paul
I understand is that in the parabolic trough, SAM does not use the total energy incident.
but, in the solar tower, it uses the total energy incident.
other notes, the hourly evolution of the gross power produced following the DNI-cosine effect product in the parabolic trough, but in the solar-paneled tower, it follows the DNI.
Can you explain why?
