2020.11.29 SAM Version Output Query
- AAKAR SHETH
22 Jul 2022 10:59 #11277
by AAKAR SHETH
2020.11.29 SAM Version Output Query was created by AAKAR SHETH
Good Morning.
I am trying to simulate a PV system scenario using 590W TRINA modules for Ground Mounted Tracking System.
Looking at the set of values that I am receiving through SAM, it is essentially double the set of values on a single year basis when I try to extrapolate any of the Voc, Isc, Vmp etc. output values in SAM 2020.11.29. This was not the case in the 2018 and 2019 SAM models.
Is there a change in how the set of values in SAM are given out for a single year ?
Any help would be greatly appreciated.
Thank you
Aakar Sheth
Black & Veatch Corporation
Good Morning.
Thank you
Aakar Sheth
22 Jul 2022 12:06 #11278
Replied by Paul Gilman on topic 2020.11.29 SAM Version Output Query
Hi Aakar,
The SAM release notes provide information about changes between versions: nrel.github.io/SAM/doc/releasenotes.html
I'm not sure I understand what results you are comparing between the different versions. If you can provide a specific example of the differences you are seeing, I can try to help you understand them.
