Manual dispatch charge and discharge rates
- Miguel
22 Jul 2022 05:58 #11276
by Miguel
Manual dispatch charge and discharge rates was created by Miguel
Hi Paul:
I hope everything is fine. I am writting this post because I am having problems to understand the manual battery dispatch. I made a simulation of PV + AC connected battery with manual dispatch. I just have two dispatch periods one for charging and one for discharging. Both rates are 10%. When the simulation starts, the system is in period 1 (charge), so I was expecting that the SoC increases by steps of 10% until the period is over. However, I am obtaining SoC step values that I am not sure where they are coming from. Could you please help me to understand this behaviour? I attach the simulation files and a screenshot of the SoC values.
Thanks in advance.
Kind regards
Miguel
Thanks in advance.
Kind regards
Miguel
27 Jul 2022 17:42 #11297
Replied by Paul Gilman on topic Manual dispatch charge and discharge rates
Hi Miguel,
In your file, the battery state of charge decreases by about 8% when the battery is discharging and increases by about 8% when it is charging. This is because of the battery minimum and maximum state of charge limits at the top of the Battery Dispatch page, which are set to 10% and 90% respectively. This means that the battery has 80% of its nominal capacity available. The "Rate" percentages for the manual dispatch option are a percentage of the available capacity in each time step, not of the nominal capacity.
