Real Discount Rate, Nominal Discount Rate
- Hamza Ali
30 Jun 2022 04:52 #11201
by Hamza Ali
Real Discount Rate, Nominal Discount Rate was created by Hamza Ali
Hello everyone.
This is Hamza.
I am doing Economical Analysis in two software. SAM and RET Screen software.
I have financial parameters let suppose,
Inflation = 8
Discount Rate = 10
So why nominal discount rate (NDR )is calculated in SAM? what is the purpose of NDR when i have inflation and real discount rate.
And when I input the same values in RET Screen software i get different results (NPV, payback period) why? even though other parameters/costs everything is same in both software.
Sam uses real discount rate or nominal discount rate for calculations?
What values I should use in both software so that i may get same NPV and PP.?
Please reply as soon as possible. I am doing a research work and I am confused what to do.
This is Hamza.
Inflation = 8
Discount Rate = 10
30 Jun 2022 14:41 #11203
Replied by Paul Gilman on topic Real Discount Rate, Nominal Discount Rate
Hi Hamza,
See the explanation for real and nominal discount rate on the Financial Parameters Help topic, for example, here is a link to the topic for the Single Owner financial model (the explanation is the same for all of the financial models): samrepo.nrelcloud.org/help/fin_single_owner.htm
In SAM, the NPV calculation uses the nominal discount rate as described in the Net Present Value topic in Help: samrepo.nrelcloud.org/help/mtf_npv.htm
SAM's financial model calculations are based on Short W et al, 1995. Manual for the Economic Evaluation of Energy Efficiency and Renewable Energy Technologies. National Renewable Energy Laboratory. NREL/TP-462-5173. www.nrel.gov/docs/legosti/old/5173.pdf
