System power generation Result interpreted
  • DAWON KIM
06 Jun 2022 09:19 #11079 by DAWON KIM
Hi!
Orange is a graph of "System power generated" blue, "Power produced without the battery or curtailment".I have a question here.
I interpreted the pink part of the attached image as the amount stored in the battery.
And the Green part used the stored energy by using the battery, so it was interpreted as a lower generation than the case of not using the battery.
I am not sure of my interpretation. Is my interpretation right?
07 Jun 2022 13:43 #11090 by Paul Gilman
Replied by Paul Gilman on topic System power generation Result interpreted
Hi Dawon,
You can use the following output variables to help answer your question:
Battery state of charge (%)
Battery cycle depth of discharge (%)
Battery relative capacity to nameplate (%)
Battery maximum charge with degradation (Ah)
Battery total charge (Ah)
Battery current (A)
Battery voltage (V)
