the centerline-to-centerline distance in meters between rows of collectors
  • lixiaofei
04 Feb 2013 19:22 #1240 by lixiaofei
Hello
In the phypical model for parabolic trough, the solar field "help" states that the default value of "row spacing" is 15m.
How to calculate precise this value for different collectors and location? because the distances derectly affect the row shadowing.
Thank you
05 Feb 2013 16:28 #1241 by Paul Gilman
You may want to try different values to find the optimal row spacing for your system design and location.
  • lixiaofei
05 Feb 2013 22:15 #1242 by lixiaofei
Thanks your help. Does it mean that i could use the function of Parametric to find the optimal row spacing the same as confirmed optimal solar multiple?
  • lixiaofei
05 Feb 2013 22:16 #1243 by lixiaofei
06 Feb 2013 13:35 #1244 by Paul Gilman
Yes. You could either change the values of the variable and run simulations by hand, or use the Parametric analysis option to run simulations for several different values of the variable.
