"gen" errors
- Sergio
28 Apr 2022 04:50 #10906
by Sergio
"gen" errors was created by Sergio
I'm working on a CSP simulation and when I run simulation next errors appears:
compute fail(tcsmolten_salt): User-vector cant method is not fully implemented (imagePlaneIntercept()).
Simulation tcsmolten_salt failed :compute fail(tcsmolten_salt): User-vector cant method is not fully implemented (imagePlaneIntercept()).
gen not assigned
Simulation utilityrate5 failed :precheck input: variable 'gen' (System power generated) required but not assigned
Simulation singleowner failed :precheck input: variable 'gen' (Net power to or from the grid) required but not assigned
How I could can fix it?
Thanks.
gen not assigned
Thanks.
29 Apr 2022 15:59 #10914
Replied by Paul Gilman on topic "gen" errors
Hi Sergio,
In my tests, I get the same error when I choose the Winter Solstice option for the heliostat canting method on the Heliostat Field page. You can avoid the issue by choosing a different canting method.
I will let the model developers know about this issue.
07 Jun 2022 13:31 - 07 Jun 2022 13:33 #11087
Hi Sergio,
This issue has been fixed internally, and will be available in the Fall 2022 release of SAM.
github.com/NREL/SAM/issues/1071
Last edit: 07 Jun 2022 13:33 by Paul Gilman.
- Albino
08 Jun 2022 09:21 #11093
by Albino
Replied by Albino on topic "gen" errors
I'm working on a Photovoltaic PV Model, and after the last actualization I have the same problem described by Sergio. I've updated the code following the link you posted ( github.com/NREL/SAM/issues/1071 ) but it still does not work.
Where could the problem be?
Kind regards
Kind regards
08 Jun 2022 15:54 #11096
Hi Albino,
GitHub issue 1071 applies to the Molten Salt Power Tower model. It does not affect the Detailed PV model.
What specific error message are you seeing?
- Albino
10 Jun 2022 02:56 #11101
by Albino
Thanks for your response. I was finnaly able to solve the error.
Kind regards
Kind regards
