Oriented system layout for detailled PV
  • feugenie
28 Apr 2022 02:08 #10904 by feugenie
Oriented system layout for detailled PV was created by feugenie
I am looking for an orientation option in the detailled PV model, if it exist.
Here my problem :
I can arrange modules facing south, on a land facing south :
__ __ __ __
__ __ __ __
__ __ __ __
__ __ __ __
__ __ __ __
I can arrange modules facing E SE (for example), on a land facing E SE :
But i can not find a way to arrange modules to face S on land facing SE :
 __
   __ __
      __ __ __
   __ __
 __
I hope that I managed to explain myself. Is there such an option in SAM ?
Thanks for your time Paul,
29 Apr 2022 16:01 #10915 by Paul Gilman
Replied by Paul Gilman on topic Oriented system layout for detailled PV
HI feugenie,
SAM does not model complex layouts. It assumes that the modules in each subarray are arranged in a rectangle.
  • feugenie
03 May 2022 07:30 - 03 May 2022 15:43 #10920 by feugenie
Replied by feugenie on topic Oriented system layout for detailled PV
Hi paul,
Thanks for you answer. Then I suppose that a good way to approach the real layout is to estimate an equivalent surface for this rectangle. Knowing that there will be loss of surface as the modules are not oriented towards the same direction as the available land.
Florian
Last edit: 03 May 2022 15:43 by Paul Gilman.
