simulating single owner PPA using different locations and system parameters
- Adam Gallaher
22 Apr 2022 13:06 #10865
by Adam Gallaher
simulating single owner PPA using different locations and system parameters was created by Adam Gallaher
I am looking to understand the various system outputs and costs for ground mounted solar projects under a single owner PPA for my study area. Rather then using one location, I would like to run my simulations at different locations in my study area using a list of lat and long values acting as the centroid of a parcel of land in my study area. Because each parcel is a different size I would also like to size the PV system based on the area of the parcel, assuming a relationship between area in acres and output in MW DC.
My goal is it iterate over simulations of system capacity at different locations. I have tried to put together a python script using pysam but have been running into issues. I am not sure how to iteratively change the solar weather file and the system capacity before running a simulation and saving the results. Any help would be greatly appreciated.
I've attached my python script for reference.
Adam
Adam
25 Apr 2022 19:26 - 25 Apr 2022 19:35 #10881
Replied by Paul Gilman on topic simulating single owner PPA using different locations and system parameters
Hi Adam,
Attached is a modified version of your Python script that worked for me.
Last edit: 25 Apr 2022 19:35 by Paul Gilman.
