PV-Battery system
  • Irene
31 Mar 2022 08:21 #10780 by Irene
PV-Battery system was created by Irene
I'm an engineering student and I'm developing a battery model for my final thesis.
I have a question related to SAM's model, specifically to the voltage model. When using the voltage-discharge curve (from the manufacturer), how do you calculate the different parameters? I mean A, B, K and Vo (the ones to fit the curve).
Thank you very much in advance.
31 Mar 2022 10:00 #10781 by Paul Gilman
Replied by Paul Gilman on topic PV-Battery system
Hi Irene,
Please see the description of the battery voltage model in Section 2.1 of DiOrio (2015) Technoeconomic Modeling of Battery Energy Storage in SAM listed on the Battery Publications page at sam.nrel.gov/battery-storage/battery-publications.html .
  • Irene
01 Apr 2022 02:57 - 01 Apr 2022 10:30 #10791 by Irene
Replied by Irene on topic PV-Battery system
Hello Paul,
Thank you very much for answering back.
I've studied in detail section 2.1 of the battery voltage model, but the issue I'm struggling with is that, in order to calculate B and K, I need the values of qexp and qnom (page 4, equations 4 and 5, image attached) and I'm not sure of how to calculate them. I think qfull is the cell capacity (Ah) at 100% SOC, but I'm not sure about the values of the current (I) and both timesteps texp and tnom, in order to be able to calculate qexp and qnom
Thank you very much in advance. I really appreciate your help.
Kind regards,
Irene.
Last edit: 01 Apr 2022 10:30 by Paul Gilman.
01 Apr 2022 10:37 #10797 by Paul Gilman
Hi Irene,
Based on the paragraph before Equations 4-5 on p. 4, it looks like the current depends on the C-rate of the discharge curve. Here is a link to the source code for the voltage model:
github.com/NREL/ssc/blob/892b81b46a66a81ed6d357bc802dd82318372c4b/shared/lib_battery_voltage.cpp#L356
  • Irene
08 Apr 2022 04:29 #10818 by Irene
Thank you very much for the reply.
I would like to ask you about another question that has arise while modeling a battery in SAM. Regarding the Electrochemical Model, when sizing the battery you have some inputs to fit the discharge curve (Cutoff voltage, Nominal zone cell voltage, Exponential cell voltage, Fully charged cell voltage, Charge removed at exponential point, Charge removed at nominal point). This inputs have some values already defined by default, and I would like to ask you if they are defined based on estimations or taken from some manufacture's datasheet.
Kind regards,
Irene.
08 Apr 2022 12:09 #10824 by Paul Gilman
Hi Irene,
The default parameters are based on our review of the literature. They are not based on information from a particular manufacturer.
