Annual snow losses
  • Lucie
22 Mar 2022 09:49 #10719 by Lucie
Annual snow losses was created by Lucie
Hello, I used SAMv2015.6.30 for few locations in the US to obtain annual snow losses but the
results are different from those in the report "Integration, Validation,
and Application of a PV Snow Coverage Model in SAM" (2017).
I used TMY2weather data and default values for the PV design as it was specified
in the report. What can explain these differences ?
Forexample, in Anchorage (AK), the annual snow losses given by SAM are
14.867% and 7.1% in the report.
Thank youfor your response
28 Mar 2022 14:54 #10739 by Paul Gilman
Replied by Paul Gilman on topic Annual snow losses
Hi Lucie,
I would recommend using the latest version of SAM, which is SAM 2021.12.02 r1. I understand if you are using the legacy SAM 2015.6.30 version to try to replicate the results shown in the 2017 paper.
If you want to use the legacy NSRDB 1961 - 1990 (often referred to as "TMY2") weather data with the latest version of SAM, you can download those files from this link: nsrdb.nrel.gov/data-sets/archives and add them to your SAM solar resource library. (You can also copy the files from the solar_resource folder your SAM 2015.6.30 installation folder to another folder on your computer and add the files from that folder.)
To add the files to the solar resource library, put them files in a folder, and click Add/remove weather file folders on the Location and Resource page to add the folder to the list that SAM scans for weather files and add them the solar resource library. That will make it possible to choose the TMY2 files from the library list.
As for the difference between the values shown in the paper and yours, did you model an array with 18 modules in a single 6 x 3 row as described on p. 11 of the paper? I've attached a file created in SAM 2015.6.30 that shows the same results as those in the paper.
