Battery Merchant - Energy Revenue Calculation
- Nicolas
22 Mar 2022 09:26 - 28 Mar 2022 14:56 #10718
by Nicolas
Battery Merchant - Energy Revenue Calculation was created by Nicolas
I'm discovering and testing the SAM Battery Merchant module. I've tried to test a simple case for a stand-alone project with only revenue from Energy Market (hourly price data). Despite entering usual/default inputs (see images below), the results don't give any revenue. It seems like the battery never charge or discharge.
Thus, could you please let me know if something seems wrong in my inputs or what could be the issue?
Thank you!
Inputs :
Thank you!
Inputs :
Last edit: 28 Mar 2022 14:56 by Paul Gilman.
28 Mar 2022 15:03 #10740
Replied by Paul Gilman on topic Battery Merchant - Energy Revenue Calculation
Hi Nicolas,
From what I can tell from your screenshots, you are using a constant power price with a constant cleared capacity requirement, and have the battery dispatch option set to "automated dispatch."
You should see the battery discharge for the first few hours of the year and then stay discharged. The automated dispatch option is designed to dispatch the battery to maximize revenue from power sales at prices that vary from time step to time step. In your case, the price is constant, so it simply discharges the battery to maximize sales, and does not charge it to avoid the cost of charging the battery.
- Nicolas
29 Mar 2022 07:28 - 29 Mar 2022 13:56 #10753
by Nicolas
Replied by Nicolas on topic Battery Merchant - Energy Revenue Calculation
Last edit: 29 Mar 2022 13:56 by Paul Gilman.
29 Mar 2022 13:58 #10756
Hi Nicolas,
These screenshots do not provide enough information for me to troubleshoot your analysis.
Please attach the .sam file you are using for this analysis if you would like me to help troubleshoot.
- Nicolas
30 Mar 2022 06:16 #10761
by Nicolas
Please see attached the .sam file corresponding to my analysis and my issue.
Nicolas.
Nicolas.
30 Mar 2022 17:16 #10771
Hi Nicolas,
Thank you for attaching your file.
As described in the Help topic for front-of-meter automated dispatch ( samrepo.nrelcloud.org/help/battery_dispatch_fom.htm ), the Merchant Plant financial model does not work well for standalone batteries because of the cleared capacity requirement.
I've attached a modified version of your file that uses your time series price data with the Single Owner financial model based on the technique described in the note in that Help topic so that the battery dispatches in response to the price data:
