Why do values/parameters cannot be changed
  • Jose
12 Mar 2022 23:19 #10665 by Jose
Hello Good day!
I am writing this to discuss why some of the parameters of the software are fixed and cannot be changed? Specifically the reference values in the financial parameters such as capital recovery factor, project financing factor and construction financing factor. How did these values get computed? Thank you
14 Mar 2022 06:39 #10673 by Paul Gilman
Replied by Paul Gilman on topic Why do values/parameters cannot be changed
Hi Jose,
I think you are asking about the inputs on the Financial Parameters page listed under "Reference Values" for the LCOE Calculator (FCR Method) financial model.
SAM calculates those values based on the inputs that you provide. You can find the equations for those calculations in Help, by clicking the Help button, or pressing the F1 key (Command-? on a Mac).
  • Jose
14 Mar 2022 19:37 #10687 by Jose
Thank you for the reply. By any chance can I get the methodology for these equations? Thank you
15 Mar 2022 10:13 #10689 by Paul Gilman
Hi Jose,
The equations for SAM's fixed-charge-rate (FCR) method of calculating the LCOE are described in detail in the "LCOE Calculator" topic of Help (listed under Financial Parameters in Help's table of contents). That topic also mentions two references that describe the methodology and provide an example of its application. Quoted from Help:
For details, see pp. 22-24 of Short W et al, 1995. Manual for the Economic Evaluation of Energy Efficiency and Renewable Energy Technologies. National Renewable Energy Laboratory. NREL/TP-462-5173. ( PDF 6.6 MB)
This method is an alternative to the cash flow method used by SAM's other financial models. It is appropriate for very preliminary stages of project feasibility analysis before you have many details about the project's costs and financial structure. It also useful for large-scale studies of market trends, such as those used for the NREL Annual Technology Baseline (ATB) study.
  • Emma
14 Feb 2023 16:29 #11928 by Emma
I noticed that my own calculations of CRF using the formula from pp. 25 of the Short manual with a nominal debt interest rate yield different results from what is generated in the "Reference Values" section of the "Financial Parameters" tab. I'm wondering if I should be using a different quantity as my rate - perhaps a real interest rate? Or a discounted one? Could you please tell me what rate is used by SAM in the CRF formula and how that rate is calculated from inputs in the "Financial Assumptions" section?
Emma
14 Feb 2023 16:35 #11929 by Paul Gilman
Hi Emma,
The equations for the values under "Reference Values" on the Financial Parameters page for the LCOE Calculator financial model are described in Help (in SAM, click Help or press the F1 key): samrepo.nrelcloud.org/help/fin_lcoefcr.htm .
