How to create srw files?
- MPetkovic
29 Jan 2013 23:14 #1218
by MPetkovic
How to create srw files? was created by MPetkovic
I want to create an srw file to model small scale wind turbines in Australia. I have all the necessary weather data but do not know how to make the srw file. Note that I have tried editing one of SAM's existing srw files in MS Excel but SAM is unable to read this edited file.
30 Jan 2013 09:50 #1219
Replied by Paul Gilman on topic How to create srw files?
Please see the description of the SRW file format in Help:
Weather File Formats
If that does not help you find the problem, please attach a copy of your file to a reply and I'll see if I can find the problem.
- MPetkovic
30 Jan 2013 15:36 #1220
by MPetkovic
Replied by MPetkovic on topic How to create srw files?
Hi Paul
Thanks for your reply. I am aware of the SAM help file. I have followed it exactly and am confident that it is set out right. The problem has to do with the file type. No matter what file type I save it as (comma delimited, tab delimited etc), SAM cannot read it. Could you please confirm what file type should be used.
30 Jan 2013 16:17 #1221
The SRW file should be comma-delimited, and use the extension .srw.
- shravannayak
07 Dec 2017 23:36 #1222
by shravannayak
Replied by shravannayak on topic How to create srw files?
Sir, is it possible to avail the wind resource data files in .srw format for Indian localities?
08 Dec 2017 09:22 #1223
I am not aware of a source of wind data in the SRW format for India. If you find data from another source, you can easily put it into the SRW format. It is a basic CSV format that is described in SAM's Help system.
