IPH linear direct steam model inputs do not correspond to the help guide
- andrea
01 Mar 2022 02:33 #10632
by andrea
IPH linear direct steam model inputs do not correspond to the help guide was created by andrea
Hi!
I am new to SAM so I am using the help guide to set up a model of a fresnel solar field for heat production.
I am using the desktop version of SAM.
According to the help guide in the system design module I should be able to specify both inlet and outlet temperature, but in the program interface there's only the field of the inlet temperature.
Given that you also need to specify the steam quality, I assume that the outlet temperature is the saturation temperature at the pressure calculated from the pressure specified in the heat sinkĀ inlet pressure field and the pressure losses. Am I right? If so, is there an alternative way to model a fresnel solar field producing heat as pressurized hot water instead of saturated steam?
01 Mar 2022 11:35 #10636
Replied by Paul Gilman on topic IPH linear direct steam model inputs do not correspond to the help guide
Hi Andrea,
That is a mistake in the Help topic for the IPH Linear Direct Steam model. There is no field outlet temperature input variable on the System Design page. I will revise that topic for the next software update.
SAM assumes that the steam quality is two-phase at the solar field outlet and completely condensed at the inlet.
You might find the recording of the 2017 webinar on modeling industrial process heat to be helpful. It is listed toward the bottom of the CSP webinars page: sam.nrel.gov/concentrating-solar-power/csp-videos.html
