Annual Degradation Schedule mode error
- Andrew James
23 Feb 2022 01:26 #10619
by Andrew James
Annual Degradation Schedule mode error was created by Andrew James
I seem to have hit a bug in the software. I am running a Detailed PV model, PPA, single owner.
I would like to input a Annual Degradation Schedule (rather than a value) and no matter what values I enter in the table (including 0, 1, 100 for each year) I always get the message :
Degradation calculated to be greater than 100%, capped at 100%.
and my simulation provides zero energy after the first year.
A few follow up questions:
- I am not sure if I am supposed to be using % or fractions, but any number fails.
- My PV panel loses 2% in the first year, then 0.25 in all other years. Is there a better way to capture this 2% initial loss. First year value must be zero, but I have to put in the second year.
24 Feb 2022 16:37 #10623
Replied by Paul Gilman on topic Annual Degradation Schedule mode error
Hi Andrew,
Yes, that's a bug, and unfortunately there is not a good workaround solution except to use a single value for degradation instead of an annual schedule.
We will fix this for the second update to SAM 2021.12.02.
github.com/NREL/SAM/issues/957
- willhobbs
01 Apr 2022 09:15 #10793
by willhobbs
Replied by willhobbs on topic Annual Degradation Schedule mode error
Paul,
Do you know the most recent version where the annual degradation schedule feature is working, in case we need that feature before the next update rolls out?
Thanks.
Will
Thanks.
Will
01 Apr 2022 10:21 #10795
Hi Will,
This problem was introduced in SAM 2021.12.02, so SAM 2020.11.29 r2 or earlier should not have the bug.
