Message Error for Detailed PV - Commercial
  • Alejandro
01 Feb 2022 05:03 #10561 by Alejandro
I am getting this error. I have googled and searched in the forum for answers but it seems that no one else is having this issue. I am using the 2021.12.2 SAM version. Could anyone please help me solving it? Thanks in advance
fail(albedo, length=12): 1
Simulation pvsamv1 failed :fail(albedo, length=12): 1
gen not assigned
Simulation utilityrate5 failed :precheck input: variable 'gen' (System power generated) required but not assigned
SSC requires input 'utility_bill_w_sys', but was not found in the SAM UI or from previous simulations
Simulation cashloan failed :precheck input: variable 'utility_bill_w_sys' (Electricity bill for system) required but not assigned
02 Feb 2022 17:13 #10565 by Paul Gilman
Replied by Paul Gilman on topic Message Error for Detailed PV - Commercial
Hi Alejandro,
Could you attach a copy of a .sam file that demonstrates these results?
That error message indicates that the monthly albedo data has 1 value instead of 12 monthly values, which should not happen unless you use an LK script to change the value of the monthly albedo input. To fix the problem, you could try the following:
1. On the Location and Resource page, expand the Albedo - Sky Diffuse Model - Irradiance Data (Advanced) panel at the bottom of the page.
2. Clear the Use albedo from weather file if available check box.
3. Click Edit values for Monthly albedo.
4. Click OK to close the window.
5. Check Use albedo from weather file if available.
  • JINANACCTEKCNC
04 Mar 2022 02:11 #10654 by JINANACCTEKCNC
Replied by JINANACCTEKCNC on topic Message Error for Detailed PV - Commercial
did you handle the issue finally?
