Field Thermal efficiency - Linear Fresnel MS - CSP
- mfrasquet
12 Dec 2021 13:17 - 13 Dec 2021 17:24 #10382
by mfrasquet
Field Thermal efficiency - Linear Fresnel MS - CSP was created by mfrasquet
Could you please guide me on the physical meaning of the variable "Field thermal efficiency" in the Linear Fresnel Molten Salt model?
Shouldn't the value of this variable be between 0 and 1? Since it is an efficiency, right?
Please find attached a picture of the hourly results in the simulation. Thank you very much!
Miguel
Miguel
Last edit: 13 Dec 2021 17:24 by Paul Gilman.
13 Dec 2021 17:38 #10388
Replied by Paul Gilman on topic Field Thermal efficiency - Linear Fresnel MS - CSP
Hi Miguel,
Those results seem to indicate something wrong with the inputs. The field thermal power absorbed should be positive, and as you note, the field thermal efficiency should be between zero and one.
Would you mind attaching the .sam file that generated these results?
- mfrasquet
14 Dec 2021 00:34 - 16 Dec 2021 09:39 #10394
by mfrasquet
Replied by mfrasquet on topic Field Thermal efficiency - Linear Fresnel MS - CSP
Thanks for your answer. Please find attached the sam input file. I'm using one specific weather file "Andasol.csv" (you will find it attached too)
You can find values of thermal eff. outside [0,1] also in the default case. The following results were obtained using the deafult model Linear Fresnel with MS - in Dagget (I have also attached the file).
Last edit: 16 Dec 2021 09:39 by Paul Gilman.
16 Dec 2021 10:02 #10407
Hi Miguel,
I think the problem is with the data in the Andasol.csv file. If you change the weather file in the Andasol_Fresnel case to daggett, the results look more reasonable.
The Andasol.csv weather file has a column for Dew Point Temperature, but the values are all zeros. The table in SAM's Help topic "Weather Data Elements" (under "Weather Data" in the table of contents) shows what weather data is required for the CSP models, including linear Fresnel.
- mfrasquet
24 Dec 2021 11:48 #10439
by mfrasquet
Thanks for the answer, I corrected the weather data. Could you please post the definition of "Field thermal efficiency"? Which is the eq used to calculate this variable?
Do you know where I can find the definition of the hourly data output variables? I tried looking in the help and the manual but I cannnot find them. Thanks very much and merry Christmas! Miguel
30 Dec 2021 16:36 #10450
Hi Miguel,
Unfortunately, we do not have a complete list of definitions for all of the CSP hourly outputs in SAM.
You can find publications describing the models here:
For the linear Fresnel molten salt model, the field thermal efficiency is very close to field thermal power produced / field thermal power absorbed.
I will ask the CSP team for a more precise definition of the field thermal efficiency.
