Negative annual energy when switching from AC connected to DC connected PVS
- Eric Brown
10 Dec 2021 10:16 #10376
by Eric Brown
Negative annual energy when switching from AC connected to DC connected PVS was created by Eric Brown
Model: PV-Battery, Single Owner
Size: 28 MW-dc, 17 MW-ac, iterating battery capacity to determine best fit
AC Connected with Manual Dispatch provides the expected increase in energy from the system.
Without changing any other inputs, switching to DC connected, automated dispatch, and perfect look ahead always delivers the following notice and has substantial negative annual energy: "Inverter oversized: The maximum inverter output was 13.34% of the rated value 16940 kWac". I'd like to only charge from the system and clipped system power and size the battery to optimize for that for now for a more simplistic case.
I'm running an external financial model and am not changing other default inputs from a NREL 2020 webinar download. The same outcome happens for a Merchant Plant SAM model. The reference file is attached.
Appreciate any thoughts.
10 Dec 2021 12:13 #10378
Replied by Paul Gilman on topic Negative annual energy when switching from AC connected to DC connected PVS
Hi Eric,
This is caused by a bug in SAM 2021.12.02: github.com/NREL/SAM/issues/856
Thank you for bringing it to our attention.
For now, please set the transformer losses on the Losses input page to zero. You can add the transformer loss to the AC wiring loss as a workaround until we fix this issue for the first update to SAM 2021.12.02, which we plan to release in January.
