Does SAM calculate radiation on the ground?
- elaheh habibi
02 Dec 2021 03:41 #10335
by elaheh habibi
Does SAM calculate radiation on the ground? was created by elaheh habibi
My thesis is about Agrivoltaic PV (APV), and I need to calculate the radiation on the ground.
Thank you
Thank you
06 Dec 2021 17:46 #10346
Replied by Paul Gilman on topic Does SAM calculate radiation on the ground?
Hi Elaheh,
SAM's photovoltaic model can use albedo data if it is in the weather file, or you can specify a monthly albedo value in the advanced parameters section at the bottom of the Location and Resource input page.
- elaheh habibi
07 Dec 2021 01:18 #10349
by elaheh habibi
Replied by elaheh habibi on topic Does SAM calculate radiation on the ground?
Hi dear Paul,
In fact "total irradiance received on the ground" is needed, useful for the crops in agrivoltaic, considering the shading effect of panels, I think albedo is not the main issue here.
Thank you
Thank you
07 Dec 2021 09:57 #10351
Hi Elaheh,
You could use the NREL National Solar Radiation Database (NSRDB) for that purpose. It provides solar radiation data for solar energy at the earth's surface: nsrdb.nrel.gov/
