Battery not Dispatching without making the cycle degradation penalty negative.
- Soheb Zaidi
30 Nov 2021 01:38 - 07 Dec 2021 22:25 #10327
by Soheb Zaidi
Battery not Dispatching without making the cycle degradation penalty negative. was created by Soheb Zaidi
Hello SAM Experts,
I have been trying to simulate FOM Solar+Battery Storage system. For this simulation I am using PV-battery,merchant model and for some reason not able to dispatch the battery.
I want to use automated battery dispatch (look ahead 18 hours). When I run the simulation with cycle degradation penalty as (calculate automatically), I can see in results that the battery computed cycle degradation penalty is 0.0107031 $/cycle-kWh. Now if I go back to dispatch and try to reduce it to 0.009 or even 0, it does not triggers battery dispatch.
However, if I enter the value as -0.009 it triggers battery dispatch.
There are 2 questions which I want to ask here:
1. How do I get the battery to dispatch with cycle degradation penalty set to as "calculate automatically".
2. Seems like $/Cycle-kWh is a very sensitive parameter, how does SAM run the codes to calculate this, if you can explain how this works that would be great.
I have attached the .sam file for reference. Please have a look.
Thanks in advance, looking forward for your reply!
Last edit: 07 Dec 2021 22:25 by Soheb Zaidi.
08 Dec 2021 15:41 #10367
Replied by Paul Gilman on topic Battery not Dispatching without making the cycle degradation penalty negative.
Hi Soheb,
Please see my reply to your other post at sam.nrel.gov/forum/forum-general/3681 .
