Defocus questions in IPH parabolic trough model
  • joey.hu
04 Nov 2021 01:01 - 04 Nov 2021 17:14 #10231 by joey.hu
I made a simulation in SAM 2020.11.29, i found a strange thing when i checked the output, as you can see from the below screenshot, the collector was defocused when the storage capacity haven't reached the limit. i have attached the simulation file for your reference, can you check it?
kind regards
Joey
Last edit: 04 Nov 2021 17:14 by Paul Gilman.
04 Nov 2021 17:20 #10236 by Paul Gilman
Replied by Paul Gilman on topic Defocus questions in IPH parabolic trough model
Hi Joey,
The field defocusing calculations respond to the storage fluid temperature rather than the state of charge. You can see that by plotting the TES hot temperature and field time-averaged outlet temperature variables.
  • joey.hu
04 Nov 2021 20:49 #10238 by joey.hu
Thanks for your quick response, i have checked the Field timestep-averaged inlet temperature and TES hot temperature on 12:00  30/6/2021 , both haven't reach the upper temperature limit, and also the Field total mass flow delivered hasen't reach the upper limit of mass flow rate definded in the solar filed input window.
kind regards
Joey
