Possible error inverter characteristics
- mkovacs
08 Oct 2021 10:22 #10119
by mkovacs
Possible error inverter characteristics was created by mkovacs
I believe the parameters for the SolarEdge 43.2 K inverter are incorrect in the current version (Version 2020.11.29). This 43.2 KW inverter has the following parameters which appear to be too small.
Paco = 14,510
Pdco = 15,020
The SolarEdge 43.2 KUS data sheet indicates:
Rated AC Power Output 43,200 Maximum AC Power Output 43,200
Regards
Mark Kovacs SE43.2KUS
Paco = 14,510
Pdco = 15,020
Regards
11 Oct 2021 15:43 #10123
Replied by Paul Gilman on topic Possible error inverter characteristics
Hi Mark,
This appears to be a problem with the data in the CEC database from which we build SAM's inverter library.
Here is a link to that inverter on the CEC Solar Equipment List app showing the incorrect nominal output power:
solarequipment.energy.ca.gov/Home/InvertersList?ManufacturerID=SolarEdge+Technologies+Ltd.&ModelNameID=SE43.2KUS+%5B208V%5D&Submit=Search&Rows=100
A workaround solution is to use the "Inverter Datasheet" option on SAM's inverter page to enter the correct information from the datasheet as described here:
sam.nrel.gov/forum/forum-general/2768
