CSP thermal storage of 24 hours!
  • Mominah Ahmad
15 Sep 2021 08:48 #10067 by Mominah Ahmad
CSP thermal storage of 24 hours! was created by Mominah Ahmad
I was trying to optimize TES for a solar tower based concentrated solar power plant at a location with average annual DNI of around 4.5 kWh/m2/day. I varied the TES to as much as 24 hours and was surprised to see the maximum capacity factor observed at this TES. I wanted to confirm if this is possible in real-world scenario since in my view HTF bypassing the direct loop would cause more thermal losses and hence the capacity factor should decrease.
Mominah Ahmad
16 Sep 2021 13:50 #10069 by Paul Gilman
Replied by Paul Gilman on topic CSP thermal storage of 24 hours!
Hi Mominah Ahmad,
You can look at the "TES thermal losses output" on the Data Tables, Time Series, Heat Map or one of the other tabs on the Results page to see if the heat losses are what you expect.
