Battery replacement simulation
  • Gabriel Konzen
25 Aug 2021 08:45 #9990 by Gabriel Konzen
Battery replacement simulation was created by Gabriel Konzen
Hello. I'm having an issue running a "Generic-Battery, Residential" simulation. I selected "replacement at specified schedule", then edited the schedule with "1" in the 11th year and edited the replacement percent with "100" in the 11th year.
When I run the simulation it seems ok given that in the cash flow it is possible to see the battery replacement cost in the 11th year.
However, I changed the replacement percent to "20" and the battery replacement cost in the cash flow was the same. I was expecting 20% of the previous cost.
Do you know what I might be doing wrong?
Thank you.
25 Aug 2021 09:33 #9993 by Paul Gilman
Replied by Paul Gilman on topic Battery replacement simulation
Hi Gabriel,
In the current version of SAM (SAM 2020.11.29 r2), there is a single input to specify the replacement percentage by year. The replacement schedule and cost are working properly in that version.
Older versions of SAM used to separate inputs to specify the year and percentage for replacements. I confirmed that the replacement cost calculation is not correct for those versions.
Please download the latest version of SAM from the SAM download page: sam.nrel.gov/download.html
  • Gabriel Konzen
25 Aug 2021 12:39 #9996 by Gabriel Konzen
Replied by Gabriel Konzen on topic Battery replacement simulation
Thank you, Paul. You're doing a great job.
GK
