P50/P90 simulation error
  • sergio castro
24 Aug 2021 14:49 #9989 by sergio castro
P50/P90 simulation error was created by sergio castro
when I do the simulation it gives me the following error:
"Calculated negative diffuse horizontal irradiance" I would like to know if this is really an error or it only appears because I am using GHI and DNI as data I attach a couple of files of the historical data that I am using:
File Attachment:
File Name: -5.170556_...24-2.csv
File Size:255 KB
File Attachment:
File Name: -5.170556_...8-24.csv
File Size:258 KB
25 Aug 2021 09:35 #9994 by Paul Gilman
Replied by Paul Gilman on topic P50/P90 simulation error
Hi Sergio,
That error message tends to be for time steps at the beginning and end of the day when the sun is low on the horizon and the array is not producing very much power. If that is the case for you, then you can ignore the messages because the problem does not have a large impact on the total monthly or annual energy value.
