My NPV values show negative values
- Weng Pin Wong
27 Jul 2021 00:38 #9875
by Weng Pin Wong
My NPV values show negative values was created by Weng Pin Wong
Good day, I actually posted a question about this negative NPV problems few months ago but cannot find the relevant post now.
I actually simulated a CSP-PTC system under Malaysia's weather but I found the NPV value is negative. May I know does this mean that CSP-PTC is not suitable to be employed in Malaysia, or is there anything I did wrongly in this simulation?
I have attached the SAM file here, hope that I can get your help on this. The file I referred to is the "untitled" file.
Thank you and stay safe!
Yours Sincerely,
Weng Pin.
Yours Sincerely,
Weng Pin.
27 Jul 2021 12:43 #9880
Replied by Paul Gilman on topic My NPV values show negative values
Hi Weng Pin,
In general, a negative NPV value means that the project costs more than it earns in revenue (or saves in electricity bill reductions).
A negative NPV could be caused by many factors, including a poor system design, high installation or operating costs, high cost of debt, high income taxes, or other factors.
- Weng Pin Wong
08 Aug 2021 00:01 #9915
by Weng Pin Wong
Replied by Weng Pin Wong on topic My NPV values show negative values
Thanks for your response!
I actually used 2 different financial models to run the same simulation case again. When I use the "Merchant" model, the NPV is still negative while the NPV is positive when I used another model called "Single Owner". May I know what factor or difference between these 2 models actually contribute to different NPV values?
Weng Pin.
Weng Pin.
16 Aug 2021 15:46 #9950
Hi Weng Pin,
If you set the Merchant Plant market price for all hours to the same value of the PPA price for the Single Owner model and all other inputs are identical, you should get the same results for the two models. This assumes the cleared capacity for all hours is 0 MW.
- Weng Pin Wong
17 Aug 2021 00:51 #9953
by Weng Pin Wong
Thanks for your reply! May I know what you mean by "cleared capacity"?
Thank you!
Weng Pin.
Thank you!
Weng Pin.
17 Aug 2021 10:00 #9958
Hi Weng Pin,
Please see the "Example Compensation Scenarios" in the Help topic for the Merchant Plant Revenue page (you can find that by pressing the F1 key on the Revenue page for a Merchant Plant project, or in the Help table of contents under "Revenue, Merchant Plant".
That shows several examples of how the merchant plant model calculates revenue based on the generation, cleared capacity, and energy price.
