wlim_series PySAM
- Maria
18 Jul 2021 06:27 #9836
by Maria
wlim_series PySAM was created by Maria
In my CSP tower model in PySAM I would like to do something similar to "Grid Limits" in the desktop version. I have read the information and I think the option that comes closest to that is to set is_wlim_series = 1 and then specify using a list or another iterable wlim_series. That's right? I have tried, but it does not limit the power output, it keeps coming out the same as always.
Here just a piece of my code.
system_model_csp.SystemControl.is_wlim_series = 1
system_model_csp.SystemControl.wlim_series = np.ones (8760) * 50
system_model_csp.execute ()
Any help or advice, I would really appreciate it.
Greetings,
Maria
Greetings,
Maria
19 Jul 2021 10:01 #9839
Replied by Paul Gilman on topic wlim_series PySAM
Hi Maria,
The 'wlim' variables are inputs to the CSP system controller. I think you want the inteconnection limit variables, which are 'enable_interconnection_limit' (number: 0=false, 1=true) and 'grid_interconnection_limit-kwac' (number: AC kW limit).
If you want a time series limit instead of a single limit, you can use 'grid_curtailment' (array: AC MW limit for each time step).
One way to find the names of these variables is to find them in SAM's user interface, and then use the LK script editor to list the variables: On the File menu, click New script, and then in the script editor, click Variables at the top of the window. You can then search variables by their labels to find the variable name.
- Maria
20 Jul 2021 20:22 #9845
by Maria
Replied by Maria on topic wlim_series PySAM
Thank you very much Paul. Those commands that you indicate are not in the Pysam information? (
nrel-pysam.readthedocs.io/en/master/modules/TcsmoltenSalt.html
). I have looked for it there, but it is not there.
Perhaps the information is not up to date yet.
Thank you very much for your help.
Maria
Maria
21 Jul 2021 09:21 #9846
Hi Maria,
Those variables are inputs to the Grid module, which is described here: nrel-pysam.readthedocs.io/en/master/modules/Grid.html
For the equivalent Molten Salt Power Tower / Single Owner Configuration in SAM, run TcsmoltenSalt, Grid, Singleowner as described here: nrel-pysam.readthedocs.io/en/master/Configs.html
