Adding Antaris Solar Modules to the CEC Performance Database
08 Jan 2013 18:31 #1135 by Paul Gilman
I would like to add the following Antaris Solar modules to the CEC Performance Database for SAM:
SM-240PC8 240 watt polycrystalline module
SM-245PC8 245 watt polycrystalline module
SM-250PC8 250 watt polycrystalline module
Here is the data sheet for these modules:
These modules are now listed on the List of Eligible SB1 Guidelines Compliant Photovoltaic Modules for California .
Thank you for your attention to this matter.
We will add these modules with the next update to SAM.
In the meantime, you can use the CEC Performance Model with User Entered Specifications module model to enter the manufacturer specifications by hand.
