Parabolic Trough Physical Model - Sizing geometry error
  • Mominah Ahmad
  • New Member
  • New Member
14 Jun 2021 10:42 #9701 by Mominah Ahmad
Hi, I am trying to simulate PTC-physical model with Solar Multiple of '3' and TES of 8 hours, the design point DNI is 708 W/m2, with rest of the parameters set as default. I am getting the following error:
exec fail(trough_physical): C_csp_trough_collector::off - freeze protection failed to converge
Simulation trough_physical failed :Piping geometry file
Maximum fluid velocity: 3.00
Minimum fluid velocity: 2.00
To section 1 header pipe diameter: 1.3208 m (52.00 in)
To section 2 header pipe diameter: 1.3208 m (52.00 in)
To section 3 header pipe diameter: 1.3208 m (52.00 in)
To section 4 header pipe diameter: 1.3208 m (52.00 in)
Loop No. | Diameter [m] | Diameter [in] | Diam. ID
     1   |    0.6350    |    25.0000     |   1
     2   |    0.6350    |    25.0000     |   1
     3   |    0.6350    |    25.0000     |   1
     4   |    0.6350    |    25.0000     |   1
     5   |    0.6350    |    25.0000     |   1
     6   |    0.6350    |    25.0000     |   1
     7   |    0.6350    |    25.0000     |   1
     8   |    0.6350    |    25.0000     |   1
     9   |    0.6350    |    25.0000     |   1
    10   |    0.6350    |    25.0000     |   1
    11   |    0.6350    |    25.0000     |   1
    12   |    0.6350    |    25.0000     |   1
    13   |    0.6350    |    25.0000     |   1
    14   |    0.7811    |    30.7500     |   2
    15   |    0.7811    |    30.7500     |   2
    16   |    0.7811    |    30.7500     |   2
    17   |    0.7811    |    30.7500     |   2
    18   |    0.7811    |    30.7500     |   2
    19   |    0.7811    |    30.7500     |   2
    20   |    0.7811    |    30.7500     |   2
    21   |    0.7811    |    30.7500     |   2
    22   |    0.7811    |    30.7500     |   2
    23   |    0.7811    |    30.7500     |   2
    24   |    0.7811    |    30.7500     |   2
    25   |    0.7811    |    30.7500     |   2
    26   |    0.7811    |    30.7500     |   2
gen not assigned
SSC requires input 'annual_energy', but was not found in the SAM UI or from previous simulations
Simulation lcoefcr failed :precheck input: variable 'annual_energy' (Annual energy production) required but not assigned
Can you please explain why is it giving this error?
  • Paul Gilman's Avatar
14 Jun 2021 16:44 #9702 by Paul Gilman
Hi Mominah Ahmad,
This message is from the piping model, which is described in Section 2.5 of Wagner (2011) "Technical Manual for the SAM Physical Trough Model," available here: sam.nrel.gov/concentrating-solar-power/csp-publications.html .
This error indicates that given the design solar field mass flow rates and other input parameters, the piping model was unable to determine a selection of piping diameters (See Section 2.5.1 in the manual).
  • Weng Pin Wong
  • Junior Member
  • Junior Member
28 Jul 2021 14:16 #9886 by Weng Pin Wong
Hi Mominah Ahmad,
May I know how do you solve this issue?
May you advise on how to solve this problem?
Weng Pin.
