Detailed steam generation costs in SAM
- Frank Mittricker
03 Jun 2021 11:54 #9652
by Frank Mittricker
Detailed steam generation costs in SAM was created by Frank Mittricker
I have read several papers on the cost inputs (and there updates) used in SAM. We are trying to determine if we can use SAM to compare our new heat transfer technology to the Shell and Tube Exchangers (STE) in SAM. We have not been able to fine a detailed cost breakdown for the steam generation section in SAM.
For example, are the safety values on the steam generation STE in the steam generation section or are they in the BOP section?
Thanks in advance.
Thanks in advance.
04 Jun 2021 10:25 #9663
Replied by Paul Gilman on topic Detailed steam generation costs in SAM
Hi Frank,
The cost categories in SAM are at a high-level, so do not explicitly show detailed costs for items like safety valves. The documents on the CSP Cost Data page of the SAM website, which it sounds like you've seen, discuss costs in the context of NREL studies of different kinds of CSP systems. As is mentioned on that page, SAM's default costs are intended as a starting point for your analysis, rather than as a reference for cost data.
The "power plant" and "balance of plant" categories on the System Costs page make it possible to compare costs for indirect salt and direct steam systems: Both of those systems would have the same power plant cost, but have different balance of plant costs to account for the additional cost of a heat exchanger for the indirect system. You could use a similar approach to account for safety valve costs.
