3D shade calculator - crashes when trying to resize or reposition
- Sangram Lamichhane
12 May 2021 09:15 #9589
by Sangram Lamichhane
3D shade calculator - crashes when trying to resize or reposition was created by Sangram Lamichhane
Hi, I have been trying to resize and reposition the objects in the 3D-shade calculator using my mouse pointer but as I click on the handles to do that, the SAM application crashes. But I can still do that by entering the values.
I am using macOS Big Sur Version 11.3. And the version of SAM that I am using is also up to date.
Is there a way to solve this?
12 May 2021 16:52 #9590
Replied by Paul Gilman on topic 3D shade calculator - crashes when trying to resize or reposition
Hi Sangram,
I don't have a solution to propose, other than the one you found to type size and position values instead of using your mouse to size and position objects.
Could you attach a copy of a .sam file with the shade scene that causes this problem, or export the scene to an .s3d file and attach that? I would like to try to replicate this issue.
12 May 2021 17:35 #9593
Replied by Sangram Lamichhane on topic 3D shade calculator - crashes when trying to resize or reposition
Thank you for the response!
I have attached a ".sam" file I was working on.
13 May 2021 10:58 #9596
Hi Sangram,
Thank you for sharing the file. I can't replicate SAM crashing when I change the size and position of objects in SAM 2020.11.29 r2 on Windows. I will have to do some testing on a Mac to see if it is a problem specific to macOS.
