Import O&M costs through LK script
- Gabriel Konzen
11 May 2021 12:26 #9586
by Gabriel Konzen
Import O&M costs through LK script was created by Gabriel Konzen
I have a "for" loop to simulate different CAPEX for a power plant. Then, i want to assign the variable 'om_fixed' as a function of CAPEX. In this case, 0.5% of CAPEX.
I realized that the variable 'om_fixed' expects an array as input. So, first of all, I'm importing a .csv file with a repetition of 0.005 for every year of the simulation.
However, when I try to run the following script, I get the error: "access violation: expected numeric, but found array".
Could you please try to help me?
active_case('example');
function array_2d_to_1d( x )
for( w=0; w<#x; w++ )
arr[w] = x[w][0];
return arr;
oem_csv = csvread('example.csv', {'skip' = 1, 'numeric'=true, 'table'=false});
oem_annual = array_2d_to_1d(oem_csv);
set('om_fixed', oem_annual * 2); //2, is just an example of a numeric variable.
check_oem = get('om_fixed');
outln(check_oem);
GK
arr[w] = x[w][0];
return arr;
outln(check_oem);
GK
12 May 2021 17:19 #9592
Replied by Paul Gilman on topic Import O&M costs through LK script
Hi GK,
Any variable that appears in the SAM user interface with a little grey and blue "val/sched" square is an array. If the array has one value, SAM interprets it as a Year 1 value and applies inflation and escalation rates to the value in out years. So, for your example you could do something like this:
x = 500;
set('om_fixed', [ x ] );
outln(check_oem);
set('om_fixed', [ x * 2 ] ); //2, is just an example of a numeric variable.
outln(check_oem);
