PC Condenser Pressure in CSP Tower
- Nicolas Machuca
26 Apr 2021 09:27 #9518
by Nicolas Machuca
PC Condenser Pressure in CSP Tower was created by Nicolas Machuca
Good morning or afternoon, i hope this days find you well,
I have a question regardind Condenser Pressure visualization in Time-Serie and in Parametric table in CSP Tower+ TES model in SAM 2020-11.-29. In parametric table seccion, I tried to check this parameter and it is showed as output in [matrix] format but after runing the simulation it does not generate the data. I checked in Time serie but i did not find the parameter to ploted. Could you help me to know why? Attached is what i am refering
Asides, is it possible to have two version of SAM installed at the same time in the same Computer?
Thanks for taking the time in advance, i look forward to your replies.
Kind Regards
Kind Regards
26 Apr 2021 10:52 - 26 Apr 2021 10:52 #9519
Replied by Paul Gilman on topic PC Condenser Pressure in CSP Tower
Hi Nicolas,
The "PC condensing pressure" output variable is only available for the Radiative condenser type (on the Power Cycle page). For the Evaporative, Air-cooled, and Hybrid condenser types, that variable does not have a value in the results.
Yes, you can install more than one version of SAM on your computer, and run them at the same time to make comparisons. By default, SAM installs on different folders on your computer, so the different versions are separate.
Last edit: 26 Apr 2021 10:52 by Paul Gilman.
- Nicolas Machuca
28 Apr 2021 09:48 #9536
by Nicolas Machuca
Replied by Nicolas Machuca on topic PC Condenser Pressure in CSP Tower
ThanksPaul, for the quick respond
I have another question regarding this topic. Accordingto "Power Cycle" page when air-cooled condenser type is selected it showed a chart with the condenser pressure as function of the ambient temperature which I assumed is calculated with the bi-variable polynomial to estimate performance of condenser in off-design conditions. setting the heat rejection
as its design condition value.
My question. When SAM compute performance of theCSP plant throughout the TMY, this polynomial used to estimate off-design conditions apply before or after the regression method used to estimate the overall power cycle performance?
Attached are the charts and equations i have referred
07 May 2021 17:40 #9563
Hi Nicolas,
The off-design performance of the air-cooled condenser is applied after the cycle performance regression calculation.
