Hi Mohammed,
Here are two things to check:
Make sure that file names in the two csvread() functions are correct.
Try running a simulation in SAM (not LK) with your weather file to make sure it is correctly formatted.
Also, when you use the simulate() function, you might try this approach to help you see when there is a problem with the simulation:
